Battery graph looks stable and good bro. continue with the charging practice.
It appears to be like sudden drop ? Bro!!
If the activity graph shows no usage and we notice drop in battery within 1 or 2 hours, then its a problem bro. you can see since 12AM till morning 7AM when the phone has no usage, your battery idle graph shows good. after you have charged and started using it.
The reduce is gradual basedo n apps we use and network condition also decides battery reduce. if instagram, facebook and calls used, battery drains bit faster. which is normal.
so for your usage it delivered 1 day performance.
Thanks robin bro
