Bro i am using iphone 15 running in ios 17.2.1 and iam facing heating issues like when ever i use the phone it getting warmer on the processor side even iam using a WhatsApp instagram also getting the same problem yesterday i visited the apple service centre they diagnosed the phone and told everything is normal and fine and i am explained the problem they told if that still warm means we can restore the ios for you bro what you think it’s an ios error or an hardware problem
Hi bro, Warm temperature is normal under certain conditions. Like if we are outside or room temperature is high, then while using any video streaming apps like instagram or youtube we see such mild increase in temperature. if its overheating then its not normal.
If there is a problem then usually it gets too much heat within few minutes of usage. say like 5 to 10 minutes usage.
Otherwise, dont worry. The phone will automatically cool down. But as a software side troubleshooting step, we can perform all settings reset once and reinstall instagram app once and check how it goes.
If you are using whatsapp for text purposes and noticing such heating, then as service center recommended, iOS Restore can be tried too. After taking full backup of the device.
But again, if its above warm temperature doing above iOS Restore is recommended. Else doing App Offload method as suggested in our channel or with upcoming whatsapp update itself such heating issues will be addressed.
Have you tried all settings reset recently?
I tried all these steps like all settings reset and uninstalling and installing an instagram app but the heating issue still continues and today iam gona restore an ios in apple service centre.
Thats the last step bro. go for it and you will notice good difference.
