Bro enoda iPhone 15 la 80% charge ana aprm charge apdiye iruku increase agamatingudhu bro. iPhone will charge after normal temperature nu varudhu bro .na konjam neram kalichu vera room la charge pannan apovum apdi dha varudhu bro , battery settings la optimised charge dha select panirukan bro . Ivlo nal charge podamodhu 80% takunu charge agum . Adhuku aprm knjm late ah 90 95% agum bro … Ana ipo 80 laye apdiye nikudhu ena panradhu bro
hi bro, current summer season and room temperature increase agurathaala temperature fast charging appo athigam aaguthunga. you can leave it connected to charger, phone cool down aanathum charge continue aagumnga.
so automatic ka manage agum dont worry. charge ku time illati continue va use pannunga till it reaches 20%. then again charge thevai padumbothu pannunga.
Ok bro , ana ipo mrng um charge panna modhu 80% vandha aprm again charge was hold notification varudhu bro ipovum 80% mela charge agala . Idhuku solution ena bro, mobile edhachu agraku chance iruka or edhachu achuna warranty claim agum ah bro . please give solution
mobile la entha problem um illainga. internal hardware damage aaga koodathunu intha measure iruku. namma bypass panna mudiyathunga. disconnect pannitu 80 vanthathum use panna arambinga. software or hardware problem illainga. temperature down aanathum charge aagum.
Ok bro
Still indha issue iruku bro
80% la stop aagudhu
Phone staring charge poda modhu heat iruku bro
Ana 80% apo heat ila ana charge was hold message varudhu bro.
Next update la dha seri agum ah bro
current summer season naala internal temperature rise aagumnga. so charge hold aagum. itha bypass pannura option ippothaiku illainga dharshan. to prevent hardware damage intha mathiri aagum.
neenga disconnect pannitu use pannunga. 20% varumbothu charge pannunga. next update la improvement irukum.
Ok bro
