Bro please reply this my iphone 15 is not charging due to water damage when i ask the apple care they said to replace some parts which cost 46k my doubt is can i use wireless charge and use my iphone for lifetime please reply
hi bro, sorry to know about water damage. It is tough to repair. almost impossible to repair. but if the phone is still working then yes you can continue using wireless charging to charge the device bro.
Based on water damage, we cannot be sure when there could be issue with battery, board or display in future bro. its electronics. so its not good to guess.
you may check with third party service center once and see if any repair possibility there or not too. But device once opened outside apple service center cannot be repaired again at apple service center.
So at our own risk we have to do that.
Like it only damaged the port
One side it is dark and another day it is normal . it is my mistake only my iphone showed liquid warning but still i charged the phone. Unga opinion eh solunga bro like will it damage my phone more ? Or can i use wireless and one more thing after this incident i can still charge my phone with wire like a lose connection sometimes it works sometimes it doesn’t. Thanks for your response bro . Can u say ur opinion about this message
if you are not seeing the warning message anymore then not to worry bro. again, water impact happened earlier could cause issue in future. namma exact a solla mudiyathunga electronics porutha varaikum.
charge only with good condition cable. that is dry and see if it works or not. what service center technician suggested? is it possible to charge or suggested to use only wireless charger?
I went to i care bro they said u should replace some parts and it cost 46k and i asked them can i use wireless charger they said yes u can then they said but its better to replace like that water phone kula yellam pogala i guess charger wire la water irunthu iruku na ath oda charge potu iruka so antha port damage aitu my fault tha bro liquid warning vanthu na atha ignore panitan .but sometimes charge pota charger agathu but i guess athu safety illa antha Iam planning to buy magsafe charger soon . Bro can u suggest any solution like can I continue using wireless or third party service but in my area there is no good service centre Iam confused bro . Warning onu varala ippom
So charging port alone damaged it seems due to water bro. in this case we have to continue with wireless charging bro. thats the only option we left with now. in future when its time to upgrade you may consider exchanging or trying with cashify like website bro.
