iPhone 15 Plus 5g network Issue
Hi bro i have a dowt about 5g network issues and call voice …is there any problem with that ?iphone 15plus
No bro. temporarily most of the 5G providers have problems with call quality overall. for data its working good. but suddenly it gets disconnected when network switching or stability problem happens on the roaming.
Try setting it to LTE mode for 2 days and use it to check the same.
No calling issues(signal strength is too good) in 5g network during call on my iphone 15. I think its based on signal strength, so u get an issues
Do try the above test case bro. whether you are facing issue when you use only LTE for 2 days. and then switch to 5G and see how it works. that will help to identify the problem.
