1.) I bought iPhone 15 plus in flipkart last Wednesday but currently I am facing battery drain issue on 15 plus what I need to do and I am using apple charger
2.)1 percent drain= 3 minutes for scrolling YouTube
hi bro, its new iPhone so it will be optimised according to your usage. dont worry. the graph looks very stable. measure battery performance over 24 hours of usage atleast. some apps uses more power like video streaming in high resolution. especially in mobile data too. dont worry, you will see improvement in coming weeks.
For heavy usage plus models give 1 day backup and moderate usage we get 1.5 days backup.
Make sure to update iOS to latest version and check for next 2 weeks bro.
I didn’t so much this gadget because battery drain comapre to my friend iphone 15 plus it seems good on battery department there is no battery issue from first days onwards and compared with friend moblie it’s very draning fast on my mobile and he told me is hardware and software issue . This phone compare to my friend moblie and i am facing heating issue while using camera and i need warranty they coverage battery section tell me bro . My average screen on time 2.5 hours
My friend told your phone draining fast on first week i didn’t face anything about battery drain from first day onwards
So i didn’t use so much this mobile compared previous device
Thalaiva replay pannu thalaivarrrae
Went out and just came back online bro. here in this forum at different time intervals we share questions and answers bro. not like chat system, but you can record your response and I will reply as soon as I come online bro.
as I said its new iPhone and according to your usage, it will adjust automatically.
Dont worry now, and you can see from the graph that idle time is really good and stable. when you used the phone reduce was happening. with this flow of usage, are you getting 1.5 days battery backup?
Bro I need to wait this month end for to optimise my battery based on my usage after that same problem is continuous what should I do ??
In limited warranty they will cover battery part solluga bro
Bro, one request. lets continue discussion here. for different discussion you can create new topic. so we wont be confused with which topic we are discussing. thanks for your understanding. ![]()
And yes, it takes 3 weeks atleast for the optimisation whenever we get a new iPhone. based on our usage normally.
1 year you have warranty bro. so dont be worried about battery health or battery performance. you have good iPhone in your hand. use it the way you want and follow the suggested charging practice. thats all it required.
within 1 year if battery health reduced to 80% then you can replace battery for free at apple service center. within 60 days from the date of purchase, if you want to extend your warranty and protect against drop and damages, you can get applecare+ too. just an information.
also from the graph above, I am saying the battery performance is really good. so dont worry about drain at all. check whether you are getting 1 day backup under above average usage or not.
Lets continue the discussion in this one post bro. saw your recent post submission about screentime.
With screne time you cannot measure the battery performance. it shows your average usage app wise.
use only last 24 hours of battery graph in batery settings page bro. As its new iPhone and under warranty, dont panick. you can get it checked once with apple service center for any defect bro. they will even perform free iOS Restore if there is any software related problem. dont worry.
I visited apple centre they told to me there is no software and hardware issue on your mobile it’s new mobile battery optimisation mechanism understand working your usage based on battery combustions it will take some time to study after that there is no battery drain issue on you mobile if you felt battery drain issue again visit the Apple Store make to repair or replacement on your mobile it will take 2 weeks maximum to optimise the battery the told
Thank you so much considering this conversation and patience talk with me
Same bro. Welcome You have the best iPhone in hand. it has excellent display, camera and other features. if some day you see battery performance difference while roaming, next day it will improve when your usage pattern changes.
even for heavy usage it delivers 1 day performance. so dont worry about battery. continue following the tips I have suggested in our channel and enjoy using your iPhone. good night bro.
