Hi,
I’m using iPhone 15 Plus, so I was using this phone past one year. Four days back, I was using my camera at morning after a few hours, my rear camera is not working suddenly. so it’s showing some camera error can you help me in this? What should I do or else it’s software issue. I attach the document below.
This could be temporary software issue bro. once restart the iPhone and continue using the device.
Is there any physical drop happened recently?
No physical damage.
No physical drop I keep my phone safely. Suddenly the rear camera didn’t work, at morning I was using it. I can’t turn on the rear camera after few hours.
If the problem is still there, then consider checking with apple service center once bro. is the device still under warranty by any chance?
Ya i can’t use the rear camera and camera was not working from last week bro. And my warranty is expired on April 2025.
This is very unusual bro. We need to check this once at apple service center. to identify any issues related to hardware level. But before that, perform “Settings - general - reset - reset all settings” once. If the issue not fixed, then we can try performing iOS Restore once.
If there is any deeper issue, then iOS Restore helps to fix such issue.
Otherwise we have to conclude it as hardware issue.
