Hai bro I m using 15 plus for last 6 months
Charging limit is 80 percent but sometimes my phone is charging 100 percent what’s the reason ??
hello bro, as per apple support document, the charging limit we set sometimes rarely overrides and that is normal. it wont happen regularly. but sometimes it happens.
dont worry, you can continue following the charging practice. that will help.
