iPhone 15 Plus Power Bank, Which one to Buy?
Bro any good quality battery power bank for 15 plus ???
Hi bro, if you are looking for wired powerbank check with URBN 10,000 or 20000 mAh powerbank. higher capacity comes with 2 USB C port.
https://amzn.openinapp.co/txz99
for Magsafe powerbank you can check this one.
any branded powerbanks can be used bro. with original or branded usb c cable for safety reasons. if its wireless magsafe, then again go with URBN, Anker or Belkin brands. they are safe to use.
Ithu safe Thana bro for iPhone ???
Yes bro. any branded wireless chargers use pannalaamnga.
Thanks bro
