iPhone 15 Plus Swipe to Answer button not working
Bro in 15 plus while answering phone calls the Swipe to answer is unable to work bro 2 3 times I have to slowly swipe to answer what is this issue bro
hi bro, could be temporary bug. is the iOS updated to latest iOS 18.3.1 version? also try restarting iPhone once and check for next 1 or 2 weeks whether the problem fixed or not.
No bro from starting this bug is there
Not fixed
normally if its software related bug updates fix it bro. else we can try all settings reset once. ā€œsettings - general - reset - reset all settingsā€.
see for one or two weeks and only if issue repeats then we have to do iOS Restore bro. if you have a computer you can do it yourself after taking backup. else we have to visit apple service center if the phone is under warranty and they will do iOS Restore bro.
that will fix any software related issue.
Ok bro
Bro while plug in the charger cable in charging port it’s titly going bro what todo
are you saying charging port is tight while putting usb c cable in iPhone charging port bro?
Yes bro
Some charging cable pins may have very minor size difference bro. but its normal. wont cause any problem. gives good grip though. you can use it bro.
Bro warranty over agura apo ethachum service center la clean panalama bro like ear speaker and speaker cleaning and charging port like this
Yes bro. within warranty la free service thaan pannuvaanga. so thevai pattuchuna pannikalaamnga.
