iPhone 15 Pro Battery consumption issue
Currently 99%
Purchase On November
Yesterday only one percentage drop
I am not putting apple care plus
If not putting apple care plus can i claim replacement
if its a defect we can claim replacement bro. otherwise we need to have applecare+. within 1 year warranty period if you want to add third party insurance, you can check with iPlanet for Protect+. so additional one year warranty similar to applecare+ will be helpful if battery reaches 80% within 2 years you can claim it too.
right now 99% is normal for 5+ months of usage. it wont reach 80% within warranty period bro. you will get 2.5 years average time to reach 80%. so dont wory and enjoy using the iPhone.
How can check it defect?
Still now overnight drain problem
upto 10% its normal bro. dont worry. notifications, network search nu normal la use aagumnga. if it drains like 20 or 30% overnight then we can check it once with apple service center. iOS Restore pannuvaanga that will help fixing it.
Use pannunga over period of weeks it will auto optimise according to your usage.
Hi brother
After restore ios now battery drain 8 -12 % overnight.
After restore background app running issue only whatsapp
Now its good bro. under or around 10% is normal. it will keep on changing in upcoming days. that background apps usage is a minor bug in battery stats. it will be changed in upcoming updates bro. right now it doesnt consume battery during that background usage.
