Iphone 15 pro nov purchase
92%
This normal drain or any issue and 8 month 8% reduce this ok?
hi bro, was it video or audio call in whatsapp most of the time? If yes then its normal only. video or audio calls normally takes more power when we use.
Hi bro, whatsapp does run in background to check notifications or to contact whatsapp server to refresh its status updates in general. It wont consume more battery power if we dont use it for whatsapp audio calls in the background.
Check in last 24 hours graph. If you are getting 1 day usage normall then not to worry. If you are seeing continues screen off time usage then we can try some troubleshooting steps.
