Bro im using iphone 15 pro mobile and the charging cable which comes with the mobile box ,i went to 2different service center they checked my mobile port and they said the problem is with charging cable and i replaced the cable with my warrenty after 10to 15days my cable again becoming loose connection i have replaced 4times upto now and now again the 4th time cable became loose if i use different cabel its working good do you have any solution for this ?i am normal user i will not use my mobile while charging and i will keep my cable by rolling after every use (roll like first time how it comes in box)
hi bro, this is totally new. if the charging port isnt a problem then something might be wrong with the way charging. you may temporarily try some third party cables like from belkin or amazon basics usb c to usb c cable and see if they are working normally or not. that should help.
