iPhone 15 pro home and lockscreen battery drain
i have tried turned off all the battery draining settings but my home and lock screen is draining my battery too much in idle . I dont know how to fix i have reset my device still i face this problem at night it drains about 45% Can you help me fix this
hi bro, that is not normal. do you have any widgets enabled and using it on home or lock screen? battery widget, stocks or any other?
iPhone model and current iOS version?
I have turned off all the widgets still facing this problem
Do perform all settings reset once bro. make sure iOS updated to latest version. then check for 2 to 3 days if home and lockscreen still showing on top in battery stats page. let me know.
I have performed all these tasks still i’m facing this problem
iOS 18.4 is coming out this week bro. update and see for a week if the problem fixed. else we have to do iOS Restore. clean installation of iOS after taking backup. you can do it yourself using a computer or by visiting apple service center in your city.
this will fix any software related issue causing such battery drain issue without usage.
