iPhone 15 pro max apple intelligence problem
Bro, my phone is 15 pro max. And I don’t have wi-fi. Can u tell bro any ways to download Apple intelligence & Siri features please
hi bro, its not possible to download it with mobile data as said in yesterdays episode. kindly wait for any places you visit like coffee shop or public wifi hotspot areas, there you can download the files in few minutes and then start using it with mobile data.
Thanks bro.And how can I effectively manage heating issues and battery drain on the iPhone 15 Pro Max?
When we have the usage we dont have to worry about it. also heating is managed automatically by the device at both hardware and software level. so we cannot do much about it.
based on apps usage and network conditions battery drain happens.
For your usage are you getting 1 day backup with 15 Pro Max?
