iPhone 15 pro max auto brightness problem
Hi bro, recently brought iphone 15 pro max. Auto brightness, true tone, face attention ellam off panni tha erruku. Ana automatic ka brightness dim aguthu bro. Game (bgmi) play pannubothu starting la brigness evlo vachi erruken no avlo erruku. Play pannitae errukum bothu sudden na dim aguthu ella time mun. Enna panrathu bro.
hello bro, auto brightness accessibility settings la off la irukumbothu, control center la irunthu brightness adjust pannunga once. then check if it stays the same bro.
again change aachuna, once ā€œsettings - general - reset - reset all settingsā€ pannunga. then auto brightness off pannitu control center la check pannunga. that will help to fix any bug.
Enakum idhe dhan bro pubg play panumbodhu brightness kamiyagudhu
auto brightness settings - accessibility - display and touch section la off la irukungala?
Bro ellam off la dhan bro irku but indha isue outdoor la irkumbodhu varudhu ena prblm , epdi fix panradhu bro???
Brights kammiyagala brightness fulla dhan irku but sudden ah dim agudhu,brightness check panna fulla dha irku but dim agirdhu
I understand bro. Normal la software issue va iruntha all settings reset pannathume fix aagumnga. Ambient light base pannitu brightness adjust agurathuku thaan autho brightness feature. Athayum off pannita namma manual la control center la vaikarathu mattum thaan work aaganumnga.
Check and let me know bro.
Bro na ennum 17.4 update pannala. Update panna ethum work aguma. Athum daily use apolam auto brightness off panni use panrathu illa , gaming apo matum tha , so periya problem illa . Ana matha user ku daily usage apo intha issue errukutha nu thrla bro. Subscribes ku intha issue pathu notice pannuga.
iOS 16 around time la intha issue namma users sollirunthanga bro. ippo recenta problem illainga. particular app or game la mattum issue appadina app developer ku notify pannitu fix pannalaamnga.
But normal la ve auto brightness work agurathu illa appadina, all settings reset once pannanum, athulayum fix agalaina iOS Restore once pannanumnga. Backup eduthutu. athula kandippa fix aagum.
Hardware level issue like ambient sensor failure can be another reason. but 99% software restore la ye fix agidumnga.
Just particular app or game la mattum intha issue varutha illa general la ve phone use pannumbothu indoor outdoor la issue irukanu once check pannitu sollunga.
Hi Bro,
Reset all setting kuduthuten again same prblm bro , only pubg play panumbodhu matum indha prblm normal ah use panumbodhu indha prblm varla bro , edhunala brightness dim agudhu sudden andha prblm fix panradhuku epdi konjam solunga ……
PubG or BGMI bro? because app updates la intha mathiri issue fix aagumnga. otherwise we have to inform the developer to release an update and fix this issue. iOS la problem a iruntha across phone same problem varum bro. even for video watching and other games.
BGMI la tha bro. Matha app la video vera games la auto brightnesse off pantu evlo set panrommo Atha brihhtness erruku. Ana BGMI la matum tha bro intha problem. Mathathu entha issue errukara mato thrla.
device or iOS issue va iruntha ella apps la yum intha issue irukumnga. so game side la brightness auto adjust pannuraanga. athunaala namma play pannumbothu back side la irunthu light display area ku varumbothu device la irukara setting override pannura mathiri theriyuthu. so brightness level auto adjust aaguthunga.
iPad la naan check pannunapo, control center la once adjust pannathum stay achu, athuva chance agala. but recently many users are reporting this problem.
I think game side bug a irukalaamnga. once game support ku notify pannunga within the game. so upcoming update la fix ethirpaarkalaamnga.
I’m also facing the same problem while watching contents in Apple TV+ with my 14 pro max
Slowly screen is turning off and turning on … it’s a 5 to 8 seconds downtime
Checked Apple’s community forum but no luck… seems like lot of other users are also facing the same issue regardless of mobile models.
Is the issue happening only with Apple TV app bro? have you tested it with youtube or other video streaming services?
