After installing 18.0.1 my iphone 15 pro max battery drains fast. The reason behind is home&lock screen using more… i have already reset my all settings and location and privacy settings. There is no change in that
Kindly share last 24 hours page screenshot bro.
do you have any lock screen or home screen widgets configured that updates continuously?
No robin… only using time and my home screen also clean
In past two days my home & lock screen battery usage was higher than these. Like 40-50%
normally if the display is ON for longer time at home screen or any widgets uses it we see that home and lockscreen showing up in battery stats bro. do one thing, try to turn off this feature.
We can observe for next 2 days how it goes.
Also, battery drain occurs between 8 and 10AM when the phone is not in use during idle time. The graph looks stable, though.
I am expecting more battery fixed with iOS 18.1 release in 2 weeks. meanwhile continue following the charging practice and we will notice improvement.
