Hello brother. My 15 pro max dropped to 98% in 4.5 months… I feel percentage drop after each update. 17.2 Apo 99% achu 17.4 piragu 98%. Idhu normal ah or should I visit service centre. I’ll add SC below
With in two months battery percentage 1% reduced with less usage. Do I need to visit service partner or it’s normal
hi bro, whether we update or not we will see battery health reduce over period of usage. if due to bugs the battery health not reduced means, it will still reduce over period of months usage. 4.5 months and 2% reduce is totally normal.
Continue following the suggested charging practice.
Overall it will maintain to reach that 80% limit around 2.5 years time.
If there is a defect then within 1 year it will reach 80% bro. within warranty period we will be able to claim battery replacement. else according to our usage it will reduce. dont worry.
Thank you so much for the response ![]()
I’m following up as advised brother. Though little worried of seeing 1% reduce
. Thanks bro I’m maintaining as same u mentioned earlier
