My 15 pro max battery cycle was 303 battery health is 89 is it good or bad
hi bro, when device purchased? month of usage?
December 15promax
for 8 months usage 11% is not normal bro. was your usage includes gaming and more screen time? you charge once a day or twice?
Not gaming bro but more than 8 hours screen time in a day and charge twice a day
Quite heavy usage may be the reason here bro. but your device is still under warranty. just when you have time visit nearest apple service center and let them run diagnostics once. just to make sure there is no defect in the device.
continue following the charging practice as suggested in our video, and that could help to maintain battery health in coming months.
I’m in srilanka here no apple store what can i do
I read that in colombo there is an apple store bro. temporarily you can continue using it bro. when you visit colombo you can check. its new model so checking outside at third party is not recommended bro.
That one is not a apple store bro that’s the authorised dealers and they said if you purchased from here then we will made a exchange and repairing under warranty otherwise they can’t
So if its time to change battery, where you will change bro? no apple authorised service center in sri lanka?
Third party service centers are available in srilanka
but it will void warranty bro. when your device is within 1 year or with applecare+ which means totally 2 years coverage. some of our audience have mentioned the availability in colombo bro. in our facebook q&a group discussion.
If there is no option then we have to check with third party service center understanding warranty will be void and we have to continue with third party service center in future too.
Hello Robin,
Greetings!
My cycle is 256 still I can see battery as 100% in iPhone 15 pro max, am using for calling and office purposes only, even checked in 3u tool regarding battery and I can see same 100%. Is that is issue or normal and
And shall I upgrade to iPhone 16 pro max or shall I hold the iPhone 15 pro max
hi bro, its not an issue bro. i hope you are following the suggested charging practice. that is all enough. continue using it and in few months it will update automatically and we will see reduce in BH. to adjust automatically.
Thanks for the response brother, so shall I use the same model, no need to upgrade right ?, please suggest
Yes bro. its absolutely good.
