Hi, I’m using an iPhone 15 Pro Max as my primary phone. I mainly use it for phone calls, browsing the internet, and using social media. The battery cycle count has reached 304, and the battery health is now at 89%. I bought the phone brand new in March last year, so it’s been about 1 year and 4 months.
I’ve also watched videos from your YouTube channel about battery-saving tips and customized my settings accordingly. Is this battery health and cycle count normal? Do you have any additional advice for me?
Hi bro, its normal battery cycle count. you can continue following the charging practice and that helps to maintain it for upcoming months. not to worry.
stay in iOS 18.5 and stable releases only to avoid battery drain issues bro. that will help.
Same bro pona varsham September la use panna aaramichen iPhone 15 pro max cycle count 240 kitta iruku but battery health 97
Oru 1 month munnadi 100 irundhuchu 2 days la 98 to 97 poiruchu
Is it usual ?
Sudden refresh aagumnga. after few months of usage suppose munnadi reduce aagama iruntha refresh agitu change aagum bro. upcoming months la same pattern irukum. charging practice namma video la sollirunthatha mattum follow pannikonga. mathapadi no issues.
Yes bro I cut at 20 and 80 but even though recent ah fast ah koraiyudhu and low battery mode potaalum drain fast ah aaguradhu feel aagudhu. And I’m in 18.5 stable
usage la ethavathu difference irukungala? just this week or recent times la thaan fast drain notice pannureengala? or since iOS 18.5 update battery backup is bad?
No bro. public beta 1 is same as developer beta 3. its safe to go back to iOS 18.5 stable release for better battery performance. you may try the beta after 2 or 3 betas after once users confirm better battery backup.
“Hey, I tried doing that once, and it showed me an error. Can you please tell me how to fix it? I can’t even open my iPhone; the screen is black.” And mention in that video which beta will be best
If there is any installation issue then we may stuck with black screen bro. its recommended to do iOS Restore once. it will wipe the phone fully erasing all data. so make sure to move to stable iOS 18 release for now if the screen is still black and you are unable to access phone home screen.
Will follow up each beta and highlight in our upcoming videos bro. expecting public beta 3 or 4 to have better stability and improvements with minor bugs.
