iPhone 15 Pro Max Battery Health Reduced
Hello brother. Today I noticed my 15 pro max battery maximum capacity degraded to 99% in 54 cycles. Device not even completed 3 months from date of purchase. I spoke to Apple technical team and they gave me an article to follow d steps as is. I said recently I did full setting reset and all are like same as showed in d article. Battery is always set to optimised. I’m completely blank. Pls help me out brother
Hello bro, for 3 months 1% reduce is totally normal. continue following the charging practice and it will be maintained well to reach 2.5 years time for average usage. just continue following the suggested charging practice. Thats all it requires.
Just like car, bike batteries as we use it will degrade. Dont worry about it. Continue using it the way you want to.
Ok brother I was little worried coz this device dropped 1% in 3 months but my 14 pro took 4.5 months. Thanks brother I’ll maintain d same as suggested
As our usage pattern changes at times and and at software level measurement we see difference between each device bro. as I said in our video, 1% a month on an average and some months we wont see any reduce too.
so dont worry about it. continue following charging practice and it will reach that 2.5 years bro. use the device normally as you would.
Ok brother I’ll follow the same. Thanks for helping out
