iPhone 15 pro max battery overcharging
I have set Charging limit up to 90 percentage. But sometimes it is getting charged fully, which means hundred percentage, why is it so?
I’m currently running oniOS 18.3.1, this problem Since I have updated, iOS 18.
Hi bro, as explained in our Charging Optimization video, its also mentioned in apple support document that sometimes it overrides the 80% charge limit set based on our usage and it wont happen frequently or affect battery health. Not to worry. You can continue updating to the latest version as its 15 pro max model.
