Hi Everyone,
Is there overheating issue in IPHONE 15 pro max due to 17 pro chip set?
Let me know if the upgradation fix is working or not to resolve the heating issue.
Hi Everyone,
hi bro, exactly when you are noticing overheating issue? while charging, while using normally or while gaming? and your current iOS version?
I too face heating issue in 15 pm . During charging only. I use apple 20w charger.
I takes around 40 mins to charge from 20 to 80 percent . Is it normal or too fast or okay .
No heating in normal usage. I’m not a gamer.
Its totally normal bro. During fast charging heating does happen. When room temperature goes down after this summer season, we will see some improvement.
Enakku normalaa use pannumbothe heating irunthuchu bro 17.4 varaikum naa kooda ellarum soldra maari design flaw pola theriyama vangitomnu than nenachan but ipo okay 17.4.1 ku aprm paravailla nalla irukku
