After updating my iPhone 15 Pro Max to iOS 17.6, I’ve noticed a Screen Time bug where it inaccurately reports 11-12 hours of daily usage on GitHub, even though I haven’t used the site only 2-3 minutes a day.
Hi bro, you can submit the post and wait for it getting approved by moderator or me. multiple submission could increase the queue. Thanks for your understanding.
About the github usage in screentime, it could be due to some widget or apps running in the background that uses certain API features. do you have any realtime status updating widget active on lock screen or home screen?
No, I don’t use any widgets related to github.
When you tap on github.com does it show the details of which app used it or more details bro?
Try this bro. Go to settings - safari - clear webhistory and data. Monitor for next 12 hours and check whether github is still using it or not. share me the screenshot too.
