I’m facing shocking issue while charging the phone pls give suggestion to solve the issue
Thank you
it could be due to poor earth line in the building bro. using 3 pin adapter with earth line helps and to prevent any issues avoid using the device while charging and use spike buster with fuse setup for charging all your electrical gadgets.
Thank for reply
Use panni pakuran bro
