iPhone 15 Pro Max - unable to transfer to hard disk
I connected my 15pro max to the external hard drive. I selected the photos and click on share.
Then selected export unmodified original.
Then I choose hard disk.
But save option was greyed out. Please let me know the proper method to transfer my photos and videos to external hard disk.
Thanks
hi bro, what is the format of hard disk? make sure its formatted to ExFAT in order to support read and write permissions when connected to your iPhone. Do check and let me know.
It is working bro. But takes time to cooy the files. Is there any app to transfer the files from iphone to windows pc, without internet?
its not possible to speed up the transfer bro. depends on several factors. is there any converted in between the hard disk and usb c cable? or direct USB C to USB C Cable between iPhone and hard disk?
Actually there is no Usb C option available bro in hard disk.
i used the connector on iphone to access USB cable
USB C to USB A Cable also good bro. Thing is make sure the hard disk is formatted to exFAT and not in NTFS which can be read and write only on Windows computers. If its exFat format then both mac and windows can perform read and write operationg on the hard disk.
