iPhone 15 Pro panel colour fade
Bro i am using iphone 15pro i am using back case from the day i got my iphone i have never dropped my phone but my side and back panel colour are fading is there any solution for this next month my mobile limited warranty is going to end and still i have not purchased any apple care or apple care plus after coloure fade can i get apple protect plus?
hi bro, normally due to environmental temperature changes and the case we use continuously touches the surface makes the metal change its color. its normal. cosmetic damages are not covered under warranty.
you can simply clean with dry cotton cloth and continue using the case to prevent any physical damage.
Applecare+ covers only for physical damages bro. not cosmetic color changes.
Thanks for your reply bro when i went to apple authorised service centre they told me if colour is peeled , faded or any damage we cannot apply apple protect pluse and they said apple company will not accept for any plans now i have gained some knowledge about it thanks bro
