iPhone 15 Pro Replacement?
Can i replce iphone 15 pro because I nearly two times replace internal board and battery
Can i clain under apple care?
The can give new phone?
hi bro, under applecare+ you can claim and get a new iPhone. If the internal board replacement done two times already, do check with apple support once for possibility of free replacement if issue is repeating. if there is no damage caused by you then applecare+ also extends manufacturer warranty to two years.
So if we get approval from apple support that will help to process it in nearest apple authorised service center.
Only if they cannot approve such free replacement then only if you are having issues now, going with applecare+ claim fee paid replacement option is ok.
OK bro
I have put apple care.for replacement iPhone is there any price will charge?
Yes bro.
each subject to a service fee of ₹2500 for screen or back glass damage, or ₹8900 for other accidental damage.
