Hi bro,
Currently I’m using iPhone 15 Pro and battery health is 87%.
is it advisable to upgrade to 16 Pro Max? How much i can quote to sell iPhone 15 Pro 256gb with apple care plus?
Hi bro,
hi bro, upgrading is not good idea for now. if 15 pro meets your requirement for every day usage then when battery reaches 80% BH then you may change battery and use it bro. only if you want the new hardware feature experience which will be minor difference, you may upgrade bro.
as you have applecare plus within 2 years period you can change battery and the device will be more capable of handling every day tasks. upgrading to 17 pro or 18 pro will be wise choice bro.
only if budget isnt an issue then you may upgrade right now bro. 15 pro current selling price is around 90K bro.
