Hai bro , slide to answer call not responsive bro I sometimes face this issue .even i checked apple community majority have faced this issue before in other iphone models.i have restored the os and checked there is no hardware issue aswell but sometimes I face the issue not able to slide othe call to answer.what is the issue bro how do we solve this?
Hello bro, Is the iOS updated to latest version? also you have enough free storage on your iPhone?
Yes bro I have enough storage and updated to ios 17.2.1
This was an old bug which got fixed with software update during iOS 16 itself bro. your iPhone model and recently replaced tempered glass or using old one?
Iphone 15model bro earlier I had other temper glass that I removed I checked without temper glass it occured after I applied new temper glass also .
Ok bro. your device is under warranty. dont worry. usually iOS Restore will fix such problem, but you have already tried it. next week when you have time, do visit apple service center once. let them run any diagnostics to identify any issue present at hardware level or not.
As they already done iOS Restore, remind them about it and still you are seeing screen freeze issue during incoming calls. let me know if they take any step on the issue.
Okay bro
