After the 16.4 upates on my iPhone 14 plus, unable to use the JIO 5G, as the 5G stand alone feature is not visible now
Yes bro. Explained in yesterdays episode about Why 5G Standalone is not enabled after iOS 16.4 Update. Kindly check
The said 5G issue has been resolved after made the network resetting.
You are now seeing 5G standalone after network settings reset bro? while using jio network?
No dear, Without standalone itself jio is working. Since our all network providers are upgrading from 4G to 5G, hence it will work as is. And this standalone feature is required for the network who provide direct 5G without the down grade of 4G/ 3G. This was the info which I got from the apple care team.
