Bro i have a doubt … i bought new iphone 16 plus …camera open panni video recording apo some stuck aaguthu moving apo and cinematic recording also …whats the reason bro
that is not normal bro. iOS updated a irukungala? iOS 18.2.1?
No bro 18.2 la dha iruku …innam 18.2.1 ku update pannala bro …and restart um panni paathuten no change apdye dhan iruku
18.2.1 update pannidunga. then check bro. same issue iruntha other troubleshooting steps try pannalaamnga.
Ok bro ipo 18.2.1 ku update panna ethum issue varuma bro like over heat and battery drain athu mari bcoz charging pandrapo heat issue iruku and mobile vaaagi 6 days dha aaguthu bro adha kekkure
no bro. its a minor update only. so update pannalaamnga. 18.2 mathiriye thaan irukum, just bug fixes.
new iPhone so background optimisation run aagumnga. heating or warm temperature athuve settle aagidum. use pannunga.
After update thee same problem bro… ipo snap or instagram la camera open panna mothu smooth ah iruku bro but nrrml ah camera open panni eduka mothu smoothness illamma slow ah move aaguthu stuck aagi bro …enna problem problem ah irukum
This is not normal bro. once perform “settings - general - reset - reset all settings” then see if the issue fixed or not bro.
Ok bro . Mobile vaagi 1 week dha aaguthu reset pandrathu naala issue la varathula bro…ipo reset panna… camera moving apo Flikkering solve aagiruma bro
its a new iPhone bro. but software issue naala intha mathiri issue iruntha all settings reset help pannumnga. just system software settings mattum than change agumnga.
so try pannitu paarunga bro.
