iPhone 16 Pro and 16 Pro Max, Which is Best?
Hi robin I’m going to buy 16 pro or 16 pro max display and battery other than that which one is best?? Any other extra features compared to both? Please explain thank you
hi bro, going with bigger model is always good choice for long term usage. if your usage is average consider 16 pro otherwise 16 pro max it is. no feature difference between them. its the bigger battery that gets you through one day when usage is heavy and 1.5 days around when usage is less.
