Hi Bro,
Whenever I use Camera in my iphone 16 pro, battery is draining fast. For ex: If I want to take more than 100 photos, i should not use other apps, internet. Then only i can take. It is happening for all iphone 16 pro users or only for me? Nov 2024, i bought the mobile and Battery percentage is 99%. For regular use, instagram and safari youtube videos, screen on time always coming 5 to 5.5 hours only.
Hello bro, 16 and 16 pro models are suitable for average usage with battery performance delivering one day. if we use apps like instagram, facebook, youtube, games or camera app which consumes more battery power, we may notice bit faster drain.
if you are going to use the camera continuously in a day for photo and video shoots, the heating will be there due to processing by both cpu and gpu. But it automatically controls the temperature.
only in outdoor heating conditions, it takes time to cool down and depending on the camera photos, videos resolution we set, the heating is very much noticeable.
Its normal for any device, even DSLR Cameras when shot in high resolution gets heating and shuts down.
16 pro heating management helps to achieve more time continuous usage. But in rare cases if you notice any such temperature warning, then we have to give some time to cool down before starting to use it.
other than camera app, do you notice heating and battery drain in days that you use normally? with apps?
No bro. Camera only reducing battery fast. Then I regularly use Instagram and Safari for youtube videos. It is coming around 5 hours screen on time.
its normal bro. camera app due to more CPU, GPU and after a photo or video taken background processing takes some extra power too. so we notice heating or battery drain with camera app.
you can try with any third party camera app too.
Ok bro. I will check. Thank you!
