iPhone 16 pro battery drain quickly in ios 18.1.1
Iphone 16 pro battery drain quickly in ios 18.1.1 when using camera. I took 600 photos and it drain 10%. New phone bought on Nov 10
Hi bro, for 600 photos 10% reduce is totally normal. can you share last 24 hours battery page screenshot?
Scroll down little bit and show top 4 to 5 apps recently used too.
Bro camera ulla poi 5 photos eduthale 1% kita less aairuthu. Oru 5 min photos and small 1min kulla video eduthale 5 to 10% less aairuthu. Na itune la software update pannen. 16pro ellarukume ipditha irukanu therla.
hi bro, camera app normal la ve battery consume pannumnga. depends on photo quality and video quality we shoot. above screenshot la camera app 26% use aagiruku. also graph stable la thaan iruku. camera app use illatha time la battery drain eppadi iruku nu paarunga.
normal usage ku 1 day battery backup varum bro. camera or video streaming athigama iruku appadina evening around 20% reach aagumnga. then charge pannunga to 80 or higher percentage based on your usage.
battery romba care eduthuku thevai padaathunga. just namma video la sollirukara charging practice follow pannitu use pannunga. upcoming updates la innum fine tuning aagum. you will get good performance overall.
Ok bro. Thank you for your comments :smiling_face:
Yeah it’s happening for me too , I purchased on Nov 2 :roll_eyes:. Phone kai la eduthalea drain aaguthu. I think it wont withstand for one full day usages
Yes sis. Normal use ku 1day varum. But camera on pannale drain aairuthu.
@iRobinPro Iphone 16 pro la photos app or other app la edit panna start pannina fast a battery drain aaguthu. Lightroom la normal edit tha pannen. 10min ku 10% less aairuthu. Camera app maari ithuve fast a drain aaguthu. Same for photos app. Ithu software update la ready aairuma? Illa pro models la ipditha drain aaguma?Ennoda old iphone 11- a paravala pola
hi bro, yes software update la kandippa improvements varumnga. but enna mathiri editing app and project work panuromnu poruthu thaan battery consumption difference irukum. battery backup athigama irukarathuku plus or max models normal better choice bro. base models 16 or 16 Pro normal one day usage ku suitable la irukumnga.
Ovvoru app poruthu evlo drain aguthunu pakuratha vida overall unga usage ku one day varuthanu paarunga. suppose one or two days athiga usage iruku appadina 20% around varumbothu noon time la kooda 30 minutes or so neenga charge pannalaam.
then again continue va use pannunga. battery drain aanalum updates la improvements irukum new model appadingrathala. dont worry bro.
Ok Bro. 16 models la intha brightness issue a solve pannirukaratha kelvi patten. Athavathu over heat aana brightness reduce aagum. Antha issue. Aana enaku apopo normal a ieukumpothe brightness less a irukara maari theriuthu. Heat aagamaiye apdi aagramaari. Service center la check pannanumangala bro?
next week iOS 18.2 update pannitu one week use pannunga. again same overheating issue iruntha iOS Restore once pannuna fix aagumnga. software level issue va iruka chance iruku. warranty irukarathaala appo namma apple service center la check pannalaamnga. within 1 year warranty coverage irukarathaala issues na service center la check pannidalaam bro.
Ok Bro. Thank you!
Hi bro 16pro use pannidu iruken once vathu pathudekana function appo continue va photo eduthudu iruthen antha time la sun light romma athikama iruthuchu na photo eduka eduka heat nalla notice panna next some lag nottice panne ithu common ah illa normally ah
hello bro, heating outdoor sunlight la camera app use pannumbothu aagumnga. its normal and few minutes break kudutha device cool down aagum bro. especially summer season la temperature athigama irukumbothu metal body appadingrathala temperature rise aagum bro. that is normal.
