iPhone 16 pro freezing and heating issues
Is it good to go for 16 pro ? I see a lot of negative reviews about freezing n heat issues , kindly clarify
as per latest reports iOS 18.1 update fixes such freezing issues bro. so next week update is rolling out. heating issues are so far not reported among our audience. if there is any such issue, then updates will address that in few weeks. experience the device once at showroom and then you may consider purchasing iPhone 16 pro.
