iPhone 16 pro max model numbers in Dubai
hi bro small dought A3295 iphone 16 pro max model is coming to middle east and japan and some other countries all are assembled in chine 3295 every country hardwarela changes irukuma like display quality cell phone signal
A3295 in uae MYWJ3J/A
MYWJ3AE/A Dubai both are samede model number number ware changes irukuma
yan friend japan model nala irukum solranga na 16 promax vangalam irukan adan na yapaodum ungalada oru suggession katutu vanguvan so only asking
hi bro, there will be no difference in cell network coverage with other country models. if the network band support is there for india region, then it shouldnt be a problem.
in UAE right now Japan, Hongkong models also sold. so UAE Region model already neenga use pannirukeenga. you can go with same UAE iPhone 16 Pro Max models, and it will be perfect fit bro.
My friend also bought Japan model and using it without issues. Just if you can find UAE model go for it. otherwise Japan model polaamnga. availability ippo japan model thaan athigam irukum pola.
amanji japan sale panranga dubai models illa A3295 model than middle east and japan
just now mobile vangidu vandan 16 pro max japan varient non active mobile nandan activate unbox pana bro
Congrats bro. use pannitu sollunga. shop la thaana vanguneenga? from same shop you bought 15 pro max from?
yes bro trusted shop bro same persion bro thanks bro
bro na japan spec use panran and my friend also using same japan spec MYWJ3J/A A3295 bro yan dought enana yan mobile display yellow tharyudu pakum podu and my friend mobile light white display madri iruku randum true tone onla iruku idu enna bro konjam explain panunga bro both are japan peace
display manufacturer 2 suppliers irukanga bro. so true tone irukumbothu light yellow shade irukum. that is normal and display color difference may be noticeable, but content view pannumbothu periya difference irukathunga. only white background or white wallpaper la thaan intha difference notice panna mudiyumnga.
ok bro thanks bro
