iPhone 16 Pro max or 17 pro max
Bro, I’m planning to buy the Pro Max model, but I’m confused between the 16 and 17 series. I’ve seen some build quality issues with the 17 Pro Max model. Please suggest which one is more practical and Overall topper..
16 pro max does comes with titanium frame which is more durable and feels better compared to 17 pro max models alumnium bro. so if you are concerned about the build difference then my suggestion is to go for 16 pro max. but only if you care about other specs internally apple made to 17 pro max, then you may go for 17 series. else 16 pro max it is.
Much appreciated, bro.
