iPhone 16 pro max purchase
Hi Bro iam planning to buy 16 pro max when i check internet there are more news regarding phone getting hang and non response and getting restart more than 10 times per day. Plz advice shall i go for the purchase or shall i wait for few more days and purchase once the issue is solved or wait and purchase 17 series as there are many rumores that festures in 17 are better than 16
hello bro, with iOS 18 initial release some issues there. Apple addressed it with next week iOS 18.1 update. So no issues buying 16 models right now. You will receive the bug fixes with software update. Not to worry.
If you have a proper phone to use you may wait and buy 17 series next september bro. if its urgent to upgrade then you may go with 16 pro series.
Ok bro thanks may be i will wait for 17 series
