iPhone 16 pro turns off automatically
Hi
Im currently using iphone 16 pro, sometimes while using my mobile screen shows loading icon and gets switched off( happened thrice for me till date) and also sometimes the scanner in the UPI apps doesn’t work. I have to restart my mobile to get it work.
Any suggestions/ anyone faced the same issue?
That is not normal bro. as its new iPhone and under warranty, kindly check once with apple service center. they have to run diagnostics to identify any issues at hardware or software level. that will help.
so far no similar reports received recently from our fellow 16 users.
