Bro
Which one would you suggest 16 Pro vs 15 Pro Max vs s24 ultra?
Usage social media, photo video.
Bro
Hi bro, if android is suitable for your every day usage, then go with S24 ultra. that will be good choice. if iOS suitable for your every day usage then you may consider 15 pro max for its bigger battery and display performance.
this one if 16 pro max, still gives good idea about 15 pro max value for money purchase with discounts right now with various sellers.
Experience both models at respective brand showrooms once or twice too bro. that helps to make your decision too.
