iPhone 17.4.1 Fast battery drain, software or hardware issue?
17.4.1 charge nikarathu illa bro over draining normal Usage also bro
Na irukara place sun over heat nallalum kuda drain aagaraku vaipu iruka bro illa update issue ah bro iphone 14 per day 2 times charge pooduren bro next update la issue seri aaeruma bro unga app la msg panna munadi 56% 5mins la 54% mobile issue kuda irukuma bro problem???
hi bro, last 24 hours battery page screenshot share pannunga. that will to understand better. show apps section visible with battery stats graph.
Deleted Instagram or any other video streaming app bro? normally with 5G usage battery consumption will be higher. but you can charge the phone in between the day when it reaches 20% or charger available. you are charging few percentage around 50% charge level. thats ok when you have continuous or heavy usage.
when you dont have heavy usage, in that days we get 1 day backup normally. for few phone calls, video streaming and camera usage.
With 9 Hours+ screen ON time, it seems good bro.
you may try this measuring tomorrow and see how it works.
I was answering same in two topics. Just noticed and closed one topic bro. in future kindly create one post for same problem. that will save us time. have a good day.
