Iphone 17 Battery heating.
Its a week older iphone 17. Whenever i charge the phone its getting hot. After removing from charge no heating issue & while using also no heating. Normal drain based on usage.
  1. Version 26.1.
  2. Removed case while charging.
  3. Not using mobile while charging.
  4. 20W charger apple charger.
Suggession please. Thanks in advance.
hi bro, due to fast charging the device normally gets such temperature rise. its managed automatically dont worry. you can leave the phone in charging and disconnect when you want to use it. using it while charging is not safe and recommended.
as you are already following the practice correctly, you will notice improvement in upcoming days.
Thanks for the reply bro
