Hi iRobinpro,
Naan iphone 13 vechirukan battery health 100 irunthuchu after 9 Months of usage it came to 96 ippo ios 17.0.1 update panna appram it became 95 and battery romba drain aguthu it seems SOT is coming for just 4hours before it was 6-7 hours and I’m a minimal user
Any tips from your side is it issue with ios 17 or we need to wait for next update …
hello bro, battery health seems to be normal. but for reduced screen on time, can you try following these tips and see any improvement happens in the next 3 to 4 days usage?
the same 16 tips will help with 17 too.
upcoming updates will bring fixes to over heating that some users are facing with 15 models and battery drain as well. but meanwhile above tips will help bro.
I have attached the Avg Screen on from my phone
Whether this is normal or any prob is there
Charging pattern should be followed like 20% and around bro. Just tomorrow charge your iPhone upto 80% or above. If it goes to 100% let it be and start using the device normally. when it reaches 20%, do share the screenshot here with apps section visible.
That will give us better idea.
Bro I have charged to 96% 27th Sep Morning 7:12AM and at 8:29PM it became 20%
The screenshots are attached and can you please suggest me whether it is normal for iphone 13 or it is draining
As well as IOS 17.0.2 came yesterday, whether I can update it or I can wait for 17.1 stable one
It does looks normal according to the apps and screen on time bro. instagram does take more battery power due to video streaming. especially in 5G. you can charge the phone whenever it reaches 20% or if you have access to charger you can charge in the middle of the day too. totally good when you have the usage. dont worry about it.
continue using it the way you want and just follow the charging practice bro.
