10 days 2 percentage drop bro
When phone purchased bro?
June 29 2023 Amazon Purchased 20 may 2024 Warranty covered bro ipo Battery percentage 89
Defect iruntha within 1 year la 80% vanthudumnga. according to our usage it will gradually reduce 1% average a month. some months it wont reduce and overall we will get 2.5 years time. in your case, 9 months 11% is high. are you following the suggested charging practice?
also how is your usage? normal or gaming?
Only normal you bro Social media 1 time charging
Rare dhan 2 time charging bro ana bro na evry upadate pannum pothu 1 Percentage korinchu bro ipo 17.4 update pannum pothu koriyala ana bro power bank la yous pannum pothu koriyara mari irukku ana athuvym travel mattum dhan epayachum dhan travel pannuvan bro power bank kum update pannum pothu dhan enkku korinchu athu nalla thriythu bro unga charging tip 2 time ku mela and aththuttan unga voice fan nalaya
Namma audience la power bank use pannuravanga feedback ketruntheanga. most of them didnt notice any battery health reduce. spigen also good brand. so not to worry. thevaipadumbothu use pannunga. with original or mfi cable always.
iPhone model bro?
Ok bro thanks for bro reply ![]()
Bro innaoru problem display vanthu Brightness fulla irunthlum power apdiya kammiya avuthu phone off outdoor layum ullayum sari phone off pannitu on panna dhan sari aguthu bro
Brightness automatic ka reduce aguthunu sollureengala? Outdoor usage appo?
Ok bro thanks bro
Bro I cloud photos konjam photos mattum delete panna mudiyuma bro sela photo s mattum
I purchased my iPhone 15 pro max on jan 15 2024. But now 1% reduced. Can you help me out on this .
Responding to your separate post bro.
Screenshot la difference theriyaathunga bro. nerla pakumbothu thaan theriyum. once “settings - general - reset - reset all settings” pannunga. then check how it goes bro.
Bro Notification sound 2 time keekuthu bro Keyboard sound off pannittan bro
Bro innoru questions I cloud la sela photos Mattum delete Panna mudiyuma bro
I cloud photos pakka mudiyuma bro
All settings reset panniteengala? also iOS updated to latest version bro? to fix that notification sound two times problem.
iCloud photos sync fulla thaan aagumnga. individual photo or video delete possible illainga. local phone la irukara photos, videos delete pannuna icloud photos sync ON la irukumbothu unga icloud account la yum delete aagumnga. we cannot change that manually bro.
