Hi bro, iPhone 13.
I bought on 07/08/2022
Battery health dropped from 100 to 99 on feb 22 on march 23 dropped to 98% again today health dropped to 97%.
And my mobile is over heating bro
Hi bro, iPhone 13.
for 7 months 3% reduce is normal bro. you can search our channel or this forum to find similar answers faster too. Here I have explained how to calculate battery health.
and you can continue follow the charging practice to maintain your iPhone Battery Health.
About iPhone Overheating problem, when you are noticing such heating issue bro? while watching videos or charging or using any specific apps?
Bro again my battery reduced to 96% bro
It may further reduce in coming weeks bro. 1% a month is normal. some months it wont reduce. overall 2.5 years average it will reach when you follow the suggested charging practice bro. dont worry.
@irobinpro… Same for me bro… 108days now on mar23 reduced to 97% and yesterday i did ios16.4 update at the time of update phone gets to heat and after the update i check the battery health it reduced to 96%(cycle count is 73)
Not even 4months complete…
I don’t know what mistakes i made… i practising the same charging advice by robin bro and cable & charger also original.
month wise calculation will be much easier bro. Oh, I wrongly took the above Rufus bro dates for your iphone purchase date.
cycle count also seems to be less in your case. heating is normal during software update. dont worry. use the phone for overall 6 months and measure it bro. around 10th or 11th month if you have any issues you can get once checked with apple service center.
if there is any defect it will reach 80% within 1 year bro. other than that, it will be maintained well. dont worry.
Bro in 9months my battery health downed to 95%.
9 months 5% iPhone battery health reduce is normal bro. dont worry. continue following same charging practice. Refer above videos.
Bro again dropped 1%
Now my battery health is at 94%.
Purchased on 07/08/2022.
From February to now totally 6% reduced
hi bro, as said in above video and suggestions 1% a month is normal. and some months you wont see reduce. suddenly it will reduce after few months usage.
Hi bro ! I am using IPhone 13 Pro bought in sep 2022
From last week I face phone overheating problem while it is getting charged and phone cuts off it’s charging automatically with a notification saying iPhone temperature is very high and mostly this occurs when phone reaches 80% and attempting to charge above 80% …
And fyi I use Apple Original adapter and cable and I leave in Chennai and there is noticeable difference in environmental temperature as well and phone software is also upto date …
Kindly advice me should I report apple service center ? Thanks in advance
hello bro, current summer season being the main reason, our room temperature increase makes the internal temperature of devices go higher than usual. you can leave the device in charging if you have time to charge it after it cools. else you can start using it and charge the device when it reaches 20% bro.
cable or adapter is not a problem here. and this doesnt require visit to apple service center. it will be fixed when temperature drops.
Sure bro! Thanks for your reply
