My mobile is replaced
November time 100% apple serviced
Now march month 97
How bro 3% droped
3 months 3% reduce. dont worry. continue following the charging practice sis. it will help to maintain it. we may not see reduce of percentage in upcoming months.
How to maintenance charging nd maintain battery health bro
simply follow these two tips sis. nothing much to do. simply use the device as you normally do in a day.
Thank you brother for ur reply im not a girl:joy:im boy brother
I am so sorry bro. DP avatar and name pathu confuse agitean
will correct it here after.
It is ok bro October month apo mobile vaaguna vaagu ios 17update pannathum mobile dead aprm apple service la mobile full replaced bro nov mobile kuduthanga back Motherboard battery full system new ah potu kuduthanga bro November month mobile kuduthanga bro apo 100% 5months la 3% droped bro now 97% Thirubi prblm edha iruka bro iPhone 14 charge nikarathu illanu mobile 2times Erase all content and settings panna bro
problem illainga. dont worry. 5 months usage ku 3% is totally normal. within warranty la irukarathaala again service center check pannalaamnga. but once last 24 hours battery page screenshot inga share pannunga. scroll down a little bit and show apps used section too in screenshot bro.
Charging eppothum 20% around pannunga. So measure pannurathuku easy ya irukum. Above graph la nethu charge pannirukeenga kadasiya. Then 30% varumbothu charge pannirukeenga.
Upto 80 or above 90% vanthathum charge disconnect pannalaamnga.
Then again next day 20 vanthathum charge pannunga. For your usage its normal bro. Dont worry.
Ahh thank you brother nd thanks for ur advice
with high instagram usage battery graph looks very stable bro. idle time overnight there is no much drain of battery. all is well.
