iPhone Battery Percentage Dropping 2% at a time
bro my iphone 14plus battery is dropping 2% at a time… for ex: at 58% and drops to 57% and with in a sec drop to 56%… and at 56% after 10 to 15mins of usage the same is repeating like drops to 55% and with in a sec drops to 54% and again 10 to15mins drops to 52%…
i restart the device also and mainting the charge cycle correctly… only 30days old device
That is not normal bro. DO perform “settings - general - reset - reset all settings” once and then see how it works. do share battery page screenshot with apps section visible. after using it for 24 hours.
Charge the phone to 100% or above 80% tomorrow morning and continue using it without charging. then we will be able to figure it out better if you share the screenshot tomorrow evening.
Same probs bro but iPhone 13 model wt can I do
still its happening bro… i did some troble shooting techmiques but its not effected… lets wait for next update bro
