Hai, can you help me with this. Which one is best for iPhone third party service? I need to replace my iPhone battery. I am not interested in changing the battery with iCare because soon I am planning to switch to a new iPhone 16. The last few days, battery health has suddenly dropped by around 5 percent. I don’t know why. I talked with Apple support, and they told me the battery degraded because of the climate. Now it’s degraded. I searched some third parties like Cashify, Yaantra, and One800 to see which one was best. Can you share your suggestions with me? @iRobinPro
hi bro, only for battery I always recommend to consider apple service center. As you are planning to upgrade the device, if you can manage with powerbank you can use it for few more months. because changing battery outside could result in quality issues. finding genuine battery outside apple service center is very tough.
Also when battery health dont show up when we change it outside, then resale value will be affected too.
Which city you are in right now? Chennai or Coimbatore is nearby to you?
Now iam in chennai only bro.
You may check with iPick Service center or iDot Repairs bro. both have good reviews among our audience. In future if there is any issue, you have to check with same service center. like battery health fast drop or any other battery specific issues.
If thats alright goahead. else consider apple service center only if you are planning to use the device for 1 or 2 years.
Thank you so much brother
Brother what about yaantra repairs?
What about yaantra repair brother?
They do look like another third party service center option bro. at your own interest you may opt for it, if its available in your city. I couldnt find any reviews so far. As you are in chennai, checking with any shops is always good idea.
