iPhone buying guide tips in 2023
Bro iphone vangalam nu iruken budget 80k thaa bro. Intha budget la ethu vangana worth for money. iphone 13 or iphone 14 or should i go for iphone 13 256gb
hi bro, iPhone 14 Plus also good choice to consider in 2023. it has bigger display and bigger battery. So you will get through 1.5 days or 1 day under heavy usage scenarios. do consider getting 256GB with good discounts and offers. that will be worth it for next few years usage.
